It is currently Thu Aug 21, 2025 4:56 pm
PostPosted: Wed Aug 28, 2013 9:24 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi,,, Need sugestions from OLFer's senior
I need to change my EUB string from: electric Bass Boomer string to WEEDWACKERS string,
My difficulty the TUNER slotted is NOT enough to fit the weedwackers (big enough), do you have the experience to this problem? thank's
here some pict I posted. duh
herry [headinwall] [uncle]
PostPosted: Wed Aug 28, 2013 10:18 pm
First name: duh
Last Name: Padma
Quick and dirty...use a file.
or
Take the machine heads to a machine shop.
These users thanked the author the Padma for the post: herry tze (Thu Aug 29, 2013 4:38 am)
PostPosted: Wed Aug 28, 2013 10:32 pm
Could you cut away the special coating at one point to allow it to fit into the tuner slot?
These users thanked the author meddlingfool for the post: herry tze (Thu Aug 29, 2013 4:44 am)
PostPosted: Thu Aug 29, 2013 4:42 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
or
Hi, Padma duh , do you mean Quick and dirty ...use a file: I must make a hole that fit to weedwackers? Can I make a hole with drill?
thank's Padma
PostPosted: Thu Aug 29, 2013 4:47 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank's, but I think oops_sign I'm afraid if I cut (thinner) that string, there will be weak...
PostPosted: Thu Aug 29, 2013 10:49 am
First name: Tony
Last Name: C
City: Brooklyn
Make a slot in the tuner post big enough for the string. Like Padma said.
http://www.CostaGuitars.com
PMoMC
These users thanked the author Tony_in_NYC for the post: herry tze (Sat Aug 31, 2013 2:04 am)
PostPosted: Thu Aug 29, 2013 1:18 pm
What size is the slot in the tuner(s) compared to the string(s)?
I see the new strings are Kevlar/nylon as opposed to wire wound, and may be a lot thicker?
Widening the slots will weaken the post at the side of the slots of course.
If widening the slot remember to round the "new" edges of this slot.
If left sharp they may damage the string.
These users thanked the author Colin North for the post: herry tze (Sun Sep 01, 2013 12:20 am)
PostPosted: Thu Aug 29, 2013 1:33 pm
First name: duh
Last Name: Padma
herry tze wrote:
or
thank's Padma
Yes however I strongly suggest using a file.
These users thanked the author the Padma for the post: herry tze (Sat Aug 31, 2013 2:07 am)
PostPosted: Sat Aug 31, 2013 2:06 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank's Tony I'll try, and for your new archtop model, she's beautiful,... :mrgreen:
PostPosted: Sun Sep 01, 2013 12:26 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
the slot size is 2,5mm and the G kevlar size is 5,0mm but I think is OK to widen,.. ONE more BIG PROBLEM is the pegbox and scroll inside is NOT enough to fill the D and G KevlaR string, do you have the other way of that? maybe I must make a hole under the pegbox? [uncle] [uncle] [uncle] gaah gaah
thank's...
PostPosted: Sun Sep 01, 2013 1:49 pm
Unless you can move the tuners up towards the top of the pegbox a couple of mm. You could plug the holes and re-drill, fitting them slightly higher.
Otherwise you may have to dig out a few mm from the pegbox to fit these strings.
If you do that I hope you have enough thickness there.
These users thanked the author Colin North for the post: herry tze (Mon Sep 02, 2013 9:46 am)
PostPosted: Mon Sep 02, 2013 9:57 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Colin, I think that's reasonable [:Y:] :D , although only two rounds that kevlar wind the slot.. thank's alot, I will soon post the picture if I've done, thank's again bliss
PostPosted: Mon Sep 02, 2013 10:08 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Colin, if the kevlar just wind the slot two rounds, is that strong enough to hold the string tension?
PostPosted: Mon Sep 02, 2013 1:19 pm
Sorry Herry, don't know - I'm not familiar with them.
They look like they are made for an Orchestral Type Acoustic Double Bass - ?
PostPosted: Fri Sep 13, 2013 11:04 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Colin I decided NOT wow7-eyes to change the string because inside the pegbox is not enough to fill with the weedwacker's string, so I think better for me, another time to build a new one EUB with weedwacker's string. Thank's all of you so much idunno bliss
Users browsing this forum: Kbore and 7 guests
